New Hole Feature Error, Potential Update Glitch
joe_dagherjoe_dagher Member Posts: 3 PRO
I'm getting this weird error when attempting to make tapped holes in the new hole feature interface. Has anyone else experienced anything like this?
  • Kevin_CowlesKevin_Cowles Member, Onshape Employees Posts: 61 PRO
    This is due to the latest update, yes, but is technically working as intended. Because you have a "Fastener fit" specified, its expecting a clearance hole in the first part, and a tapped hole in the second part (used to be the Clearance and Tapped, blind in last option). If you change Fastener fit to be "None", you'll resolve the error.
  • joe_dagherjoe_dagher Member Posts: 3 PRO
    OK great thanks!
  • blefroy_exsblefroy_exs Member Posts: 15
    edited March 2024
    I keep getting this as well, but I have 'None' selected in 'Fastener Fit'? Also, would it be possible to change the default 'Fastener Fit' setting to 'None' please, as I suspect for most people a tapped hole in a single body is the first use of the tool, and a 'blind-in-last' (as it was) is less frequently used.
