Cut an assembly
robert_scott_jr_
Member Posts: 766 ✭✭✭
in General
For a clockface I have made a weave of oak strips. One strip of the weave was modeled in a part studio and then mirrored to create a like strip. The two strips' wide faces to eventually be fastened 90 degrees to each other. I modeled each opposing weave in assemblies and the married them together in another assembly. The shape and other features of the clock's frame is not yet decided. I would like to be able to cut out shapes from the married assembly to use in different frame configurations. Alas, no boolean or split in an assembly. Is there a work around for this or must I create the entire weave in a part studio? - Scotty
https://cad.onshape.com/documents/d88c835daead1b6b03142a47/w/d12c0623662d6fc6ddabd048/e/24461b925321f0f68dbb3f74
https://learn.onshape.com/learn/course/managed-in-context-design/introduction-to-managed-in-context-workflows/what-is-managed-in-context-design
The only way to use context editing (it is hardly true context editing) is to start a new in-context part studio from your assembly, window select all the parts and transform-copy them, then cut away. This is very messy (creates copies of all parts) but it can help to get where you need to be and harness the power of assemblies.
Are Onshape intending a proper fix for this that doesn't involve messy copying of parts? It seems quite a basic feature that's missing from the program to me from past experience. (Think e.g. machining bearing journals installed at each end of a housing in one machining op to maintain correct runout as a pair). If somebody could link me to a feature improvement request I'd happily upvote it.
