How can I draw a geodesic dome according to Paul Robinsons method
stefan_schumm
Member Posts: 11 ✭
in Drawings
Hi,
I`d like to draw a geodesic dome according to Paul Robinsons tutorials he made for sketchup I would like to use Paul method to construct an Icosahedron as base and then develop v1, v2, v3 and so on geodesic dome. The link to Pauls YouTube channel is the following:
I appreciate your help in advance.
Thank you.
Stefan
Thank you.
Stefan
then create the faces for one "section" and "transform pattern them using the faces of the isocahedron...
The transform pattern was a bit tedious to setup... I'm sure there's a simpler way to do it...
https://cad.onshape.com/documents/2262070be426079d04985ad7/w/96c2b073fdb827bda5d505fb/e/1a6f063cb48236b5d90b8d78
Much easier using circular patterns:
https://cad.onshape.com/documents/2262070be426079d04985ad7/w/96c2b073fdb827bda5d505fb/e/4bcd31a40b79b28549e63837?renderMode=0&tangentEdgeStyle=1&uiState=65fc99575b5973718d101ef3
thank you for your instant help. I will dive in immediatly.
https://cad.onshape.com/documents/d5306cfba78302e095f825d3/w/decc970565b34e8ea39fd369/e/b8017e7f0ec58c208a636034
