I have a problem with adding thickness to an object
adel_saadanyadel_saadany Member Posts: 2 EDU
I'm having a situation where I can't add thickness to an item with a mesh. I cannot even extrude on such surface. Can I even turn off the mesh? If someone could propose a solution, it would be greatly appreciated.
https://cad.onshape.com/documents/c6a5971e16d7a9d1f8d1f5bd/w/634b2a0bbd84ac29d61334ce/e/89f65b0917bfcf72df172cb7?renderMode=0&uiState=66044e3b0784ab0600b842d2
  • S1monS1mon Member Posts: 3,751 PRO
    Why are you starting with an STL file in the first place? Can you get a Parasolid or STEP?
    It's possible to clean up mesh files, but it would be much better if you didn't have to.
