AI tool to enhance your renders: magnific.ai (maybe helps improve render studio results?)
alnisalnis Member, Developers Posts: 453 EDU
I happened across https://magnific.ai in the newsletter "This Week in 3D" from Andrew Price (https://www.poliigon.com/thisweekin3d).
In short, it's an upscaling + detail adding tool that uses generative AI to improve images: hand drawn, photos, renders, etc...
Of course, I'm most interested in the render part, to see how can things I make be made to look more photorealistic (or just cooler.)
Here are some samples of inputs and outputs, prompt is at the end of this post.
Since they don't have a free trial, let me know if you have any images you'd like me to run through it. Post your render here, and I'll post back with the generated result.
I just ask that you limit them to no more than about 1000x1000 pixels, since the cost scales a lot with image size.
Onshape render of mecanum wheel:
AI output:
Render of underwater robot (done in Blender since Render Studio kept crashing):
AI output:
The prompt/setup (same for both images):
  • francisco_sandafrancisco_sanda Member Posts: 2
    Could you try with this?
  • Ste_WilsonSte_Wilson Member Posts: 574 EDU
    @alnis it might just be because I'm looking at it on mobile but... I can't tell the difference!
  • RhettRobinsonRhettRobinson Member Posts: 201 ✭✭✭
    You can tell especially on the mecanum wheel, it's probably since you are on mobile. This is neat!
    @alnis will this work with a picture that isn't rendered?
  • MichaelPascoeMichaelPascoe Member Posts: 2,808 PRO
    edited April 2024
    Legit!
    Here is one you can try. It's pretty good except the food is a little under-cooked and plasticky. Table is too clean as well.
    size 1000 x 563
    RENDERCAD
  • alnisalnis Member, Developers Posts: 453 EDU
    @francisco_sanda here it is, same prompt & settings as what I used for my original post, except "optimized for" is "standard":
    Here it is "optimized for" set to "3d render":
    @Ste_Wilson it's pretty subtle! Here is a close up of one area:
    @Rhett_Robinson yes - it has the following modes:
    @MichaelPascoe here it is! "standard" optimization mode:
    "3d render" optimization mode:
  • _anton_anton Member, Onshape Employees Posts: 525 image
    That's a really nice result on the table. In principle, a lot of this could be done in a Render Studio manually, but much more laboriously.
    Cool! Ty @alnis
    @_anton, Yeah, its a cube that I slapped a material onto XD.
    RENDERCAD
  • S1monS1mon Member Posts: 4,048 PRO
    The more extreme example of using AI for rendering is Vizcom.ai.
    https://www.vizcom.ai/
    With limited sketches and text you get an ai rendering. It's not going to replace the real thing all the time, but it is useful enough to get a lot of buzz and funding.
