John Steven Bowers
john_bowers023
Member Posts: 2 ✭
Fairly new to Onshape. I am printing on a Creality K1 Max printer with a couple projects successfully completed.
I need to design a shift boot, which will seal a airplane nose wheel steering rod where it goes through the firewall. The rod is a 10 mm diameter rod, and passes through a 14 mm X 60 mm vertical slot (because of the nose wheel up and down movement during takeoff and landing. I will use TPU filament because of its pliability.
What is an easy method to produce the flexing sides of the part??
Draw a squigly line.
Sweep it around an elipse or oval or something to make a surface.
Thicken.
Shape? Round, square, other? - Scotty0
Thicken.
In my experience, flexible 3D printed parts are really only durable enough for a short term proof of concept prototype. If this part is life-critical, I would question using 3D printing.
1 -
Agree with Simon. That said, if you've got the budget, this stuff is amazing:
https://www.stratasys.com/en/materials/materials-catalog/fdm-materials/tpu-92a/
1 -
I think that Formlab just released a silicone resin for their brand of 3D printers and that may work better than TPU.1
