Fitting a contour on an 3D export of your face
noname_nolastname740
Member Posts: 2 ✭
Hi all,
I am pretty new and was looking for how to do a few things but all the tutorials I found did not seem to be what I was looking for (Im a bit of experience in fusion, but little in onshape)
What I am aiming to do is to create a fitted quest 3 Vr Interface: the idea came from: The idea
https://www.youtube.com/watch?v=P-HauBK_NFc
I have a standard VR interface (thank you thingieverse) which I want to "cut" at the base and then extrude on a 3D render of my head (on which I draw a contour to fit towards the cut part of the thingieverse STL.
Can anyone recommend the specific tutorials that can help me? I seem to find rather complicated ones.
thanks
https://www.youtube.com/watch?v=P-HauBK_NFcI have a standard VR interface (thank you thingieverse) which I want to "cut" at the base and then extrude on a 3D render of my head (on which I draw a contour to fit towards the cut part of the thingieverse STL.
thanks
Here is the best way to learn Onshape imo, Learning Pathways - Onshape Learning Center
Onshape can handle the modeling side of it no problem. The app does have a lidar scanner option if you have an iPhone or iPad. Note: I have not been able to get usable data by scanning with the Onshape app; so you will probably need to find another app to scan your face then import the stl into Onshape.
▚▞▚▞▚▞▚▞▚0
