Unhide Components
Kevin_Gallichan
Kevin_Gallichan Member, pcbaevp Posts: 6 ✭
I have some parts and assemblies within a larger assembly.
I want to unhide one of the assemblies. When I click the eye next to the assembly, nothing is shown.
So to unhide the assembly,  I have to expand the assembly in the tree and also every sub-assembly and click each individual component to show it.
If the assembly is hidden, I can select show all but that shows everything so it's not what I want.
I'm looking for the "show all assembly" command that filters down and shows everything just within the assembly selected.
Is there such a command ?
Is there a better way to show the parts I need to seee ?
Thanks
    Hello Kevin - there is only "show all instances" or expand everything and shift-select then show.
  • Kevin_Gallichan
    Really - no way to select an asembly and show all of that assembly.
    This is pretty basic functionality.
    How do we add improvement suggestions to the list ?
    edited May 2024
    As a paid customer, you should use the "Contact Support" option in the help menu inside Onshape.
  • Shiv_Charan_Madan
    Shiv_Charan_Madan Member Posts: 8 PRO
    https://onshape.zendesk.com/hc/en-us/requests/369382
    I have already raised this ticket. @Kevin_Gallichan
    I don't understand what is meant by status: HOLD-LOGGED.
