How to pass different configuration paramaters
I’m trying to construct a passer to restore the data from a CAD design, to speed up, I used configurations to modify my data quicky as shown in below:
However, once I tried to pass it by using request('post', '/api/partstudios/d/' + did + '/w/' + wid + '/e/' + eid + '/featurescript/', body=body),
I found that the responds ignore those Sketch’s configuration parameters by only response the default parameters as shown in follow:
In the meantime, above code correctly response the configuration parameters in ‘Extrude’. May I know why, and may I know how to pass those configuration parameters in Sketch for different configuration? An example of the respond is shown in below for your information:
Thank you for your attention to this matter.
