How to create an internal thread on a turned part
bruce_fischer469
Member Posts: 16 EDU
in General
can anybody tell me how to create an internal thread on a turned part (see screenshot)? The external thread command doesn't work here. Of course, I could use a bore for the thread, however, this will remove the pin in the middle as well and I would need to recreate it afterwards. From other CAD Software I'm used to have a thread command that works for external and internal threads.
Another question is how to use fine threads. Indeed, the intended pitch is 0,75 mm here. Is there a possibility to implement this?
Best regards
https://cad.onshape.com/documents/6b640a407d78066bd5e41c7a/w/4693805578a72f40ebfb4ea3/e/c953720c264ce001f1a82dc1
https://cad.onshape.com/documents/5c0528b62c1fbb13a2a0e739/v/f86229e7f586f8517a2068a9/e/7cbb452d4d5e963a034ce616?jumpToIndex=2851
