How do I convert from surface to a part?
Hello,
https://cad.onshape.com/documents/5cab9c8bd0c06800a23058dd/w/21f41b44ed254d01afa55610/e/7c29c9f531cc0f9dfe76bf91?renderMode=0&uiState=661944bfbb351732e9895119
I am having trouble with this CAD model of an aircraft where I want to make it a part instead of a surface. As you can see, the object is already filled at the wings but Onshape sees it as a surface. I tried using the enclose and Thicken but nothing worked as there are errors.
Thank you.
  • GWS50
    GWS50 Member Posts: 538 PRO
    edited April 2024 Answer ✓
    Here is the model as a part.
    There was an 'open' section that was preventing the surface becoming a part.
    https://cad.onshape.com/documents/3ea65f25053bd9d55bef6189/w/b1a36d33a30fc385c9ad95fd/e/c067ff590abb44c4de9af93f
    A helpful way to locate these open areas is to extrude a surface and use it to perform a split in the imported surface and then use the enclose command to see if one side of the split will then become a solid part. By moving the splitting surface to different locations you can then isolate the offending area. (See Part Studio 2 TAB)
    I hope this makes sense
    S1mon Member Posts: 4,638 PRO
    You'll need to make your document public in order for us to help.
  • abdulla_hadrami
    abdulla_hadrami Member Posts: 5 ✭
    I made it public
  • GWS50
  • abdulla_hadrami
    Thank you so much!
  • martin_kopplow
    There should be a diagnosis-tool to find open faces or bad surface joints in OS. That has been an industry standard for years im many CAD systems.
  • GWS50
    you can use 'Highlight Boundary Edges' but it's not always that clearly shown with a complicated open surface, (can be hard to spot)
