How to link part marking with part revision property.
AustinPackard
Member Posts: 7 ✭✭
I currently use the part revision property in my export rules to automatically include the part revision in the name of my exported files. I would like to be able to use the part revision property to drive part markings in a part studio. The part markings are debossed on the parts directly. Currently, I make a variable with the revision text and input that variable as an expression in the text field of the part marking sketch feature. Every revision update, I need to make sure to update the revision in both the part properties and this variable. Is it possible to make the part property drive the variable or vice versa? Or is there a way to use part properties as expressions in the text box dialog directly?
