API | PartStudio | Mass Properties
Martyn_GierlickiMartyn_Gierlicki Member, csevp Posts: 3 PRO
Hi all -
I am using the Glassworks API Explorer to pull the mass properties from a part studio (https://cad.onshape.com/glassworks/explorer/#/PartStudio/getPartStudioMassProperties).
I am pulling the data into Excel Power Query via the generated Request URL from the glasswork API tool.
Now - my part studio contains muliple configurations which contain various quantities of parts. I know I can hard call a specific configuration into the URL to GET the details of that specific part studio configuration but is it possible to generate a single request URL for all of the configuartions within a part studio.
I have in the region of 80 configurations so dont particularly want to have to create 80 URL's and 80 power queries.
Thanks in advance.
  • Caden_ArmstrongCaden_Armstrong Member Posts: 393 PRO
    A single request cannot represent all of the configurations, you will have to run your request against each and every configuration.
    You can use the endpoint:
    /elements/.../configuration
    to get a list all of the parameters of a configuration, and then use the allowed values to generate a list of all of the configurations.
    For inputs like length, these are obviously infinitely variable, so you will need to determine a method of iterating across that value, or leaving it as a default.
  • devil_forddevil_ford Member Posts: 2
    The mass properties of a solid object are its mass, centre of gravity, centroid, volume, moments of inertia, products of inertia and radii of gyration. Since the mass refers to a solid object, you can only find the mass properties of a solid model.
  • husso_ndroshusso_ndros Member Posts: 4
    Good question! From what I see, the API call only lets you pass a single configuration at a time. Is there any way to request all configurations in bulk for a Part Studio, or would this have to be handled by looping through the config list outside the API?
