Making a drawing template to reuse in sketch
in Drawings
Hey all, I m new to onshape. Sorry in advance if it is a silly question.
My only CAD experience is TinkerCad (if you consider it as a CAD software). I m looking for similar functionality to grouping in TinkerCad. It groups all the tiny parts into one single part. Then I can multiply it.
I searched 'template' and 'grouping' in onshape docs and forum. But apparently there are other concepts with these names.
I m drawing for 3d print.
You can see my documents. Here is one:
I m trying to draw a new part for my new keyboard. The document is base sketch of left side of my keyboard. As you can see there are 24 holes for 24 keyboard switches. I created 2 variables. One for distance between switches, one for switch side length. If I change a variable, changes on all the boxes(switch holes) is being reflected. Good feature.
But I need more. I want to create a box in somewhere with some holes inside it. Then I want to use it like a template. Then I want to put it multiple times somewhere I want to.
Here is an analogy for my need:
Imagine you are designing a book cover in onshape in sketch mode without extruding. And let's say that book cover contains a bunch of texts and star-drawings. And you want to draw the star once and put to some specific places around text. When you change star template, it will reflect to all starts on sketch.
I hope that make sense.
Thanks for reading it.
One for the switch is going to solve my problems. But if the usage is convenient, I would like to use more.
In here, if you take a look at this; I have a box. Inside it, there are 3 circles, 1 half circle and 2 lines. All are black.
But when I copy them, there are some blue lines. I need to put number of constraints. Doing this for other 20+ boxes are hard and open to mistake. And let's say, I did once, and printed, and wanted to change one thing, I will need to do this change for every boxes. Creating this box and put the things that I need as a component, and using this one as a component in my skecth, is going to level up my experince
https://cad.onshape.com/documents/e02c339da17a82eb16add09e/w/3b68e6d62c74006043ef7c11/e/e355c41c42ff91a2123c3543
Check out the super derive custom feature, might do what you want to achieve. It works with sketches too.
https://cad.onshape.com/documents/cfef86ed4f9635531599a973/w/def12fa727cba59c54c7c45d/e/1ca336dd47d98dd00918c589
Any questions, let me know. Cheers
Thanks for your time and effort @David_YL_Nguyen @robert_scott_jr_
