Can You Edit Circular Patterns?
elijah_bell514elijah_bell514 Member Posts: 8
Can you edit a circular pattern after you have made it if so how?
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 933 PRO
    Yes.  Right-click -> Edit... or double-click.
  • martin_kopplowmartin_kopplow Member Posts: 1,288 PRO
    edited April 2024
    It depends.
    • If you created it in 3D in an assembly or a part studio: Yes, just edit the feature.
    • If you created it in a sketch: Might get tricky. You need to edit the sketch and modify the dimensions created by the pattern tool.
    Before you make changes to the dimension, make sure the changes reflect what you want and E.G. first fix the pattern member you don't want to move!
