copy from one document to another
don_howedon_howe Member Posts: 136 ✭✭✭
Is it possible to copy from one onshape document into another?
I have an onshape document named Delta 12-1/2 planer cabinet. In this document I modeled the planner, though it is not an assembly just a part studio. I want to copy the features into a new onshape document.
Can I do this, and how?
If I can't, then I'll just have to remodel it.
  • don_howedon_howe Member Posts: 136 ✭✭✭
    Okay, I think I just figured out how to do this. I used the "move to document" command.
  • rick_randallrick_randall Member Posts: 412 ✭✭✭
    edited May 2024
    If you want a copy of a part studio (keeping the original) - then I think you need to look at "duplicate" - right click the part's name tab (down at the bottom of the graphics area), then select duplicate. This will create a new part (the whole part studio) with the same name only followed by (copy 1). You can rename later. And I believe all x-refs to the original are broken (correct me if I'm wrong).
      good luck
