View Perpendicular to Face - Drawing?
thomas_crosbythomas_crosby Member Posts: 2 EDU
I have designed a thin element that has angles and I am trying to create a DXF file for it to be laser cut. However, when I go to insert the part into a drawing it is only giving me options to insert front, back, bottom, left, isometric, etc. views. If I do the left view, the part dimensions will be slightly off due to the angle.
Can someone suggest a solve?
