Inability to fillet after sweeping on two projected lines around a cone
torin_clark
torin_clark Member Posts: 7 ✭
Hi there,
I'm trying to design a finger support ring for my friend and I'm having some issues with filleting the area between the two sections.
Initially I created this from two solid sweeps and tried to boolean them together, however the boolean failed (probably for the same reason) and i had to generate it as two surfaces before enclosing the full shape.
Looking closer at the join between the halves, it seems to become jagged and non-continuous, though (in theory) it should be straight.
so that's...weird.
Could someone please help me work out how to better do this? If there is another method I should be using to smoothen the line, or an alternative method of generating the shape?
Model available here:
https://cad.onshape.com/documents/d6077c7ee0c7fbe17e2ae9de/w/b05ac21e8f0f77390cb35e3b/e/05e615edf04076c347286cd2?renderMode=0&uiState=663fb88c37ae1d39f46eb36b
Thank you in advance!
