How to create a custom linking some parts
willian_tamagiwillian_tamagi Member Posts: 12
Hi folks,
I have no idea how to do this. I have 3 parts that I want to use to create a custom case. I used the Loft tool to create the surfaces that close the case, but I needed to create a 2 mm-thick wall instead.
Here is where I am:
https://cad.onshape.com/documents/5df57d0b368a4dc7fb78a3f6/w/b5aa6b633eea9c49dbc18cc0/e/e64130d77121b3b0c3817ae6?renderMode=0&uiState=66424fb46c7e2a7439ee9177
  • rafael_telgmannrafael_telgmann Member Posts: 138 ✭✭✭
    If I understand you correctly, then it may be that all you need to do is to use the "Thicken" feature.
    The minimum inner radius of your face must be at least as large as the thickness to avoid intersections/errors.
Howdy, Stranger!
