Selection N compound curves and generate a piece wise approximation and print to debug
brad_phelan
brad_phelan Member Posts: 91 ✭✭
I have a funny use case. I'd like to use the onshape sketcher to draw curves. Then I'd like a feature that can select N curves and process them to get piece wise linear approximations and then dump the points to the console or debug. My exact case is that when writing test cases in c++ I often have to generate small geometric features and it would be easier  if I could sketch them then dump the points to paste into my code as a c++ initializer list.
