Educator Plan Simulation Clarification
colin_starker933colin_starker933 Member Posts: 34 EDU
I searched far and wide on how to actually start a simulation because there seemed to be no such commands. Every video started with a simulation already present. I have the Educator plan. We are currently using ANSYS and are transitioning to OnShape. It would be convenient to have our fluid/stress FEA consolidated into OnShape with the solid models.
It is stated that this plan has simulation capability here:
Was simulation capability removed from Educator?
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 924 PRO
    edited May 2024
    When you log into Onshape, you should see "Subscription: Educator" in the bottom left.  If that's the case, go to an assembly and you will see the simulation tools at the top.
    Add a force, moment, etc. and you have yourself a simulation!
    Currently, static and modal, no fluid.
  • colin_starker933colin_starker933 Member Posts: 34 EDU
    edited May 2024
    It never occurred to me that you had to be in an assembly. It's not possible to isolate it to single part?
  • S1monS1mon Member Posts: 3,994 PRO
    You can make a dummy ground part, and mate your part under test to it. As you get more and more into doing FEA, you will find that you'll likely want to create fixture or ground parts and you'll probably want a separate test assembly from whatever your main assembly is.
