can someone help
billy_bowersbilly_bowers Member Posts: 5
trying  to make a gear with only I/4 of the circle has teeth that's driven by a complete gear    ,  once it has turn 1/4  and runs out of teeth the 1/4 gear  needs to stops .  letting the drive gear to continue rotating  driving  others gears.  tried using slots but same problem as soon as the drive handle  moves out of the slot it should stop but continues to rotate .
  how can I make it stop.
