Using curves to add to a part
daniel_crookstondaniel_crookston Member Posts: 14
Hi,
I've got this part (wire bender) that I'd like to beef up a bit.  I've got some mirrored bridging curves, and I'd like to fill in the space between those curves and the tube that projects out the side.  I've tried adding surfaces, extruding, etc. and can't get it to work.  Can anyone help me out?
https://cad.onshape.com/documents/902349103e20abb782112e2f/w/1c74d1840bad12d33f4b9582/e/53f7142e60297f692aee75d2?renderMode=0&uiState=664b59d753f2250ee9462c14
Thank you!
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 841 PRO
    Not as fun as curves and fills, but a simple extrude would beef the part up a bit.
  • daniel_crookstondaniel_crookston Member Posts: 14
    Looks good, did you just edit the original sketch to add that teardrop bit?
    I actually added a new sketch.
