<p>Welcome to the Onshape forum! Ask questions and join in the discussions about everything Onshape.</p></p><strong>First time visiting? Here are some places to start:</strong></p><ol style="list-style:inherit;margin-left:25px;"><li>Looking for a certain topic? Check out the <a href="https://forum.onshape.com/categories">categories filter</a> or use Search (upper right).</li><li>Need support? <a href="https://forum.onshape.com/post/question/community-support">Ask a question</a> to our <a href="https://forum.onshape.com/categories/community-support">Community Support</a> category.</li><li>Please submit support tickets for bugs but you can request improvements in the <a href="https://forum.onshape.com/categories/product-feedback">Product Feedback category</a>.</li><li>Be respectful, on topic and if you see a problem, Flag it.</li></ol><p>If you would like to contact our Community Manager personally, feel free to <a href="https://forum.onshape.com/profile/6/LouGallo">send a private message</a> or <a href="mailto:lgallo@onshape.com">an email</a>.
</p>
Can you hollow a loft?
paul_pastura
paul_pastura Member Posts: 4 ✭
Hi I am trying to design a case insert to 3D print and I would be very grateful if someone could help me with the last piece which is to simply remove the bottom face and hollow it out to leave me 2.5mm shell.  I have tried Shell, Boolean subtract and all sorts of funky workarounds and I am pulling my hair out.  It seems that the thickest shell I can achieve is 0.1mm
Please help - Thanks in advance
here is the link to the document: https://cad.onshape.com/documents/6f76ead8e246cd0ff90f146c/w/e41de55ac8f0a3c5b22f57ca/e/35481979d7be1e1827872307
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,948 PRO
    Hey @paul_pastura, this issue is probably happening around this area.
    Try simplifying the shape or a copy of the shape so that when the shell or thicken calculates, the faces don't intersect each other too much when the 2.5mm offset takes place.
    For more detailed help, please make your document copy-able.
  • MichaelPascoe
  • paul_pastura
    Thanks, I suspected as much. I've revised the design and taken a new approach which makes it easier to print too.
