Cant open document
jayden_lee350jayden_lee350 Member Posts: 2 EDU
I cant open a document because it would turn into this.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 941 PRO
    edited May 2024
    Upon upload, in your notifications pane (the bell in the top right), you should see a message that "box v1.stl" was translated successfully.  If so, you will have the actual .stl file in your "CAD Imports" and look through your other tabs and you should see a "box v1" Part studio.  Click the home icon to get back to the other tabs.  Or, you can open your tab manager with alt+t or option+t to look for it.  The tab manager is even searchable.
