Drawing Shaded View Quality Issues
imants_smidchensimants_smidchens Member Posts: 69 EDU
Hello! Is there any way to improve the quality of shaded views in drawings?
The view properties are already set to "Best quality" etc.
I've attached the view properties dialog, as well as several problematic areas from one drawing.
These areas all look fine in the regular 3D view.
https://cad.onshape.com/documents/6eb1d47ad2b5b4b375c60fae/w/ea628258f7d101b3908e2cdb/e/bbc757eab3580f8070a056c5
Here's what it looks like in the 3D view:
VS in the drawing:
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,589 PRO
    I've run into this before...
    You should be able to improve this by setting the tesselation quality manually for these parts and then updating the drawing, or maybe even switching you assembly to "show in high quality" (not sure if that will work...)
