Watermark in drawing template always in front of drawing views
johannes_wjohannes_w Member Posts: 33 PRO
Hello there!
When creating a drawing template with a watermark, the watermark picture is always placed in front of all drawing views.
Even if I send the picture to the back and move it to the border in the template, as soon as I use the template in my drawings, it gets sent to the front. I have to unlock the border manually, send the picture to the back an lock it again directly in every drawing. As soon as I update the drawing, the picture gets send to the front again. I would consider this a bug, since there is no case where the current behaviour makes sense.
Does anyone else have this problem?
Thanks!
  • matteo_correzzolamatteo_correzzola Member Posts: 4 PRO
    Hi, we have the same problem, we tried all possible workaround without any success. We opened a support ticket, if we get any good solution we will share the info with you.
    Hi, we had the smae problem, we asked support and they told us they will let us know when fixed
  • johannes_wjohannes_w Member Posts: 33 PRO
    Hi, thank you for your update! Same here. The behavior has improved but is not completely gone. When I update the drawing, the image stays in the back. But when I create a new drawing with the template and drop my first view into the drawing, the same problem occurs. Please fix this onshape, I have to create many drawings with a watermark, and this is getting cumbersome.
  • AuroraRonAuroraRon Member Posts: 141 PRO
    Same issue. Can't have any watermarks. This seems like such a basic function :-(
