Show parts with errors
AuroraRonAuroraRon Member Posts: 139 PRO
Onshape has issues with importing large assemblies.
While 50% of the parts are said to have errors, they DO display but not in a drawing.
Is there a way to make the parts show and not be ignored in drawings?
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,549 PRO
    I think there's an option in drawings to "show faulty parts" as they are hidden by default.
  • AuroraRonAuroraRon Member Posts: 139 PRO
    Found it!
    Thank you. Had to find the item that was not showing up as you see below then right click on it to show/hide fault parts.
    Now just need to work through why over 50% of imports have fault parts but this one issue is solved. Thanks.
