Where can I learn about acoustics in design?
Ulises_FMUlises_FM Member Posts: 74 PRO
I'm currently redesigning a case for a high speed electric motor.
The motor by itself is pretty quiet, it can get up to 50.000rpm and you would only notice a litte humming. However, when I place it inside the motor casing, the noise level rises considerably.
The case is working as a resonant cavity and I honestly have no idea what design changes to implement since I have little background in acoustics. I know the principles and the basic physics behind, but I wonder if you guys would know of any resources about acoustics focused on design. I would appreciate if you could share them, or even give me some advice or rule of thumb.
Everything I find on the internet is related to room soundproofing but the solutions they use dont apply to my design.
Cheers!
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 895 PRO
    Onshape Simulation does modal analysis, giving you the vibrational modes of your design.  Stiffening the motor casing will tend to increase the natural frequency.
