Fail to publish feature, missing description from exported/imported feature
stuart_robinson
stuart_robinson Member Posts: 37 ✭✭
i'm trying to publish this feature Variable Surface Text to add variable text to parts.  i found one that looked like it used to work so i took it as an featurescript exercise for myself and tweaked it so it works great for me now.  it's using "export import(...)" a feature called Surface Text
but it wont let me publish because Surface Text doesn't have a description
removing the export doesn't work
i'm guessing this description annotation is a new requirement? can i give a description to an imported feature? or anything else i can do to publish?
i dont really understand why it has to be exported for me to use the enum parameter
