sheet metal complex bends
joshua_reed558joshua_reed558 Member Posts: 2 EDU
hi guys
I am trying to make a sheet metal model of this part so i can print it and use it as a template but am struggling with the corners as there are 2 competing radius's. does anyone know of a way to make it work
  • rafael_telgmannrafael_telgmann Member Posts: 138 ✭✭✭
    As far i know, there is no deep-drowing feature in sheet metal. You have to model this in the conventional way (shell-feature)
  • wayne_sauderwayne_sauder Member, csevp Posts: 632 PRO
    @joshua_reed558
    How would you manufacture something like that using standard sheet metal processes? As mentioned, the modeling process looks different for the printing or stamping processes.
    If you need a flat pattern for it, check the app store.
