Multipage drawing translation into separate JPG-files
OKT_trial_23
Member Posts: 3 PRO
It's possible through API translate multisheet drawings into separate JPEG-files (and download them) where JPEG-name will be derived from associated sheet name? Any API that gives information about the number of sheets in a drawing, the order of the sheets and the names of the sheets?
If you are only looking in glassworks, its not clear, but there is an endpoint documented in the developer documentation that does provide the sheets (in order) with names from a drawing. Its the "Export Drawing as Json" endpoint.
The result is a JSON with Sheets and Views, and the sheet information includes the names of the sheets.
https://onshape-public.github.io/docs/api-adv/translation/#export-a-drawing-as-a-json
www.smartbenchsoftware.com --- Renaissance --- Kestrel -- SmartLink
Experts in Onshape Automation - Custom Features and Integrated Applications0
Experts in Onshape Automation - Custom Features and Integrated Applications0 -
Thanks for the help! I found inside JSON-file all need information of drawing's sheets.
