Pairing with OnShape Vision
timo_engströmtimo_engström Member Posts: 2
I've bought the Apple Vision Pro, and the main reason is to take part in the evolution of CAD in AR.
OnShape seems to be the best option so far.
I have updated OnShape on the iPad Pro, OnShape Vision on the AVP and the latest iOS and VisionOS.
But when trying to pair OnShape tels me to update the OnShape Vision to the latest version.
Anyone else who has encountered this problem and found a solution?
  • yicong_xuyicong_xu Member Posts: 6
    @timo_schönberger Hi, good to hear that you are using the latest products from Apple and PTC. The version number can be checked in the app store on both devices. Are you with Onshape iOS 1.182 and Onshape Vision app 1.6? These should be the latest version. I believe 1 version back should also be compatible though. We're also conducting more tests.
