Issue with merging parts - Bug or Misunderstanding?
jeremy_temple
jeremy_temple Member Posts: 2 EDU
I love Onshape as it's a fairly simple CAD software I can use on anything for free, but I've been having this issue occasionally that really bugs me. Sometimes, when creating multiple sections from the same sketch which I intend to add/merge together, I get an error and end up having to add them as separate parts. They can't be merged with a boolean afterwards, either. Am I missing something, or is this just a bug in the software? Thanks for any guidance
Example of issue:
  • nick_papageorge_dayjob
    From the screenshot it looks like it’s probably non-manifold geometry. It means surfaces come to a sharp edge/point in a nutshell. No cad system can do that, it’s not mathematical possible.
    Go through your sketch and re-do it and it should work.
    S1mon Member Posts: 4,644 PRO
    @nick_papageorge073
    No Parasolid based CAD system can do it. The Granite kernel that Creo uses can handle these types of non-manifold situations, but they are only so useful as they don't represent something which is manufacturable.
  • rick_randall
    rick_randall Member Posts: 444 ✭✭✭
    edited June 2024
    I believe it's the inner circle that's giving you the error, you might try changing it to a construction line (highlight and type "Q"), or deleting it (it's function is not really apparent to me)
    Hope this helps, good luck
