Move a set of lines (generated through DXF) when a plane resizes
29_1819
Member Posts: 5 ✭
Hey everyone!
- so I created a custom text line through Inkscape and imported as DXF in onshape
- I stick that DXF as lines on a plane
- when the plane resizes, those lines stays on the same place (it clips if the plane becomes smaller)
Welcome to Onshape! @29_1819In order to have a sketch follow a dimension, it must be properly constrained, fully black lines not blue. See this Learning Pathway. Once your sketch is fully constrained, then it will follow your dimension in a predictable way depending on how you set up your constraints.◉ RENDERCAD - Photorealistic product rendering.◉ CADSharp - Professional CAD + software consulting.
▚▞▚▞▚▞▚▞▚0 -
Does the text have a bounding box, like OnShape text? If so, try to dimension the box. I'm not familiar with Inkscape so ignore this advice if it doesn't apply.
@rick_randall has an excellent point. If there are a million small splines from an import, don't bother constraining those. In that case, make sure there are no dimensions or constraints on it except for 1 dimension which will scale the entire sketch.
▚▞▚▞▚▞▚▞▚0 -
Hey everyone, thank you so much for the answers, unfortunately its very impractical to manually constrain the imported DXF sketch as it does import a million small splines points and lines... I was hoping there was a way to automatically constrain the sketch so I can make this sketch follow a distance so it does not clip when a plane changes size.0
