What would be the best way to mate the holes on this servo to the holes on the part under it?
I am trying to make it so the holes of the servo are concentric with the holes on the part under the servo without the holes touching each other.
I've tried using a planar mate to constrain the servo to the face of the part, and two cylindrical mates for the holes. The second cylindrical mate causes an error.
robert_scott_jr_ Member Posts: 595 ✭✭✭
Don't know what the best way is. One way is to find the angle between the alignment of the holes of the part you are mounting to and the alignment of the holes of the servo. Then use a Fasten mate, using the dialog within the mate feature to attain the correct orientation. Example below. - Scotty
https://cad.onshape.com/documents/c0c91324d87e9aee51c1fd5c/w/ba449dcb6d0f2a771b5e19b8/e/e001229374425e42b841f4d4
1
