Elevation mechanism mysteriously misaligned
massimo_asteritimassimo_asteriti Member Posts: 5 EDU
I designed a simple elevation mechanism for a drop-down metal basket that's supposed to fit squarely into a compartment of equal size. However, despite making sure all of my measurements are correct, something is somehow misaligned such that the basket itself is slightly askew despite every other component being perfectly in place. I can't imagine what could possibly be causing this and it's driving me insane. Here's the link to my project: https://cad.onshape.com/documents/476aaecb595d495f5f31dd85/w/d685f01f7d8cb82fb3f15524/e/0d1c3e21528d5da6171338ae
  • dirk_van_der_vaartdirk_van_der_vaart Member Posts: 561 ✭✭✭
    After insert of the bottom (misaligned) first fix the part and then insert the other parts with the mateconnectors
  • massimo_asteritimassimo_asteriti Member Posts: 5 EDU
    I tried that, when I insert the part from the part studio into the assembly, it's perfectly aligned just like everything else; however, when I connect it all with the pin slot and revolute mates, then it suddenly becomes misaligned.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,252 image
    Use the measurement tools -- on your bottom part, the hole on the right is a slightly different distance from the top than the slot.  I think that's the issue.
    I just checked the sketch and both the slot and hole on the bottom part are exactly 0.25 m from the top, although the slot had a radius that was slightly off which I fixed. I double checked with the measurement tools, but the issue persists.
  • james_aguilar160james_aguilar160 Member Posts: 57 ✭✭
    What measurements are the red numbers referring to here?
    On further introspection, I see that I've not added anything to answer your question -- of course if the tops are misaligned the pins are going to be misaligned in the slots too. I wonder if what is happening is simple numerical error on the part of Onshape. With so many parts in sequence, maybe its solver begins accumulating error as it goes? Anyway, what I mean to say is I don't know. :( According to my inspection, there is already error even by the time you get to the end of the first arm pair of joints. I tried doing things like adding a parallel mate and that overdefines the assembly. Maybe someone else will have some better ideas.
  • wayne_sauderwayne_sauder Member, csevp Posts: 635 PRO
    @massimo_asteriti
     Study fully constraining your sketches. And maybe part design vs assembly. You should only be modeling one of every part.
     Some of your circles are off by just a bit. I fixed a couple of issues; if done correctly, it all works out as parallel. I did not complete the whole assembly nor spend time ensuring no interferences.
    https://cad.onshape.com/documents/59c01a756ade521c414c340a/w/6bec8080af27b67a9c5e400a/e/e0d0305ada39d01a7f5bc337
    @massimo_asteriti
    Thank you so much! I will look into fully constraining sketches for sure; just out of curiosity, what exactly was off about my circles? I was quite confident I had dimensioned all of them properly, but I guess not.
     I didn't spend much time figuring out all the issues, but if I remember right, you had your midpoint pivot on the part 2 constrained midpoint on a line that went from the center of the bottom circle to the edge of the top circle. The one on part 1 is driven by a dimension. I think this is the issue, but I'm not sure without digging through it a lot more.
