Partial circle centreline
Jasper_KearneyJasper_Kearney Member Posts: 2 PRO
Hi, is there a way to draw a circle centreline/bolt circle diameter as a partial arc?
What I would like to achieve (I did this by sketching an arc in the part then showing it in the drawing):
What currently happens when using the drawing tools (2 or 3 point circle centreline):
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 540
    @Jasper_Kearney on the gif below, when I adjust the arc centermark extension, I'm holding the shift key to just adjust that one portion:
    If you modeled your part with a hole feature and circular patterned that - we do provide circular centermark patterns as a part of view creation.  You can edit the automatic circular centermark patterns and unselect the same elements as I did in the manual tool, and then adjust the arc centermark extension in the same way as above.
