(Not answered) How can I measure the normal distance from a face to a point in an assembly?
![josh_targo](https://profiles.onshape.com/1cfdfc80cbb3c809ffa13572a22471f195b722ca3291bcdd7b4216f881e6d5be.png)
Just click on the two entities you want to measure the distance from. in the bottom right there is a small measuring tape. Just click on it and you will receive the different distances.
Hope this helps you out. There is also the Shortcut " [ " for measurements, if you like that more.
CADSharp - We make custom features and integrated Onshape apps! cadsharp.com/featurescripts 💎
"Just make a part studio" is not the answer I want. This should be a trivial modification for the programmers.
https://cad.onshape.com/documents/598cadbc051409bdac78f7d1/w/fdd69096d199077d71a0ac6b/e/7fba283c12f4ce5935a92d2f?renderMode=0&uiState=66858c3f7c86921adcb7c4e7
Vote up improvement here:
https://forum.onshape.com/discussion/24790/measure-tool-to-give-perpendicular-normal-to-measurement-for-point-and-plane-selections-in-assembly#latest
