How to i connect this rod to two end clips, which mate connector need to be used
shravan_rajbhar235shravan_rajbhar235 Member Posts: 2
Hi everyone!
this is my first post. can anybody help me how do i connect this rod to two end clips just connection required no precision. i tried Tangent connector, it worked well for one side but while i try tangent connector it fails.
pls see attached pic. end clips have balls there, just wanted to touch this rod to these balls.
But Not working at right clip, same thress tangent connectors? can anybody pls guide.
  • robert_scott_jr_robert_scott_jr_ Member Posts: 743 ✭✭✭
    It looks like you'll have to model that bar so the faces of the bar ends and the faces of the ears that it appears intended to fit into are parallel. See what happens when you suppress the tangent mate of the end that works and then apply a tangent mate to the end that does not work. - Scotty
