crating a nut for existing specific size bolt
rlbrkrlbrk Member Posts: 31
Hi. I'm pretty new to onshape.
I'm looking to crate an m4 nut to a screw I alredy have.
I saw some youtube about it but in every video there is the model of the hex screw already and they just subtracting the nut from the hex screw.
i got a physical screw to crate a nut for. what do you need to change in the helix tab to make both function nice with each other?
I also saw that there are different options to crate the helix pattern or size, like pitch and revolution, pitch and height, revolutions and height, height and turn angle... what should I pick for this job?
thanks
  • james_aguilar160james_aguilar160 Member Posts: 57 ✭✭
    I would probably use the Hole tool. You can specify that the hole is tapped for an m4 screw. AFAICT OnShape doesn't render the threads, presumably to save rendering resources. That's fine, though, because it's very unlikely you own anything capable of producing the physical geometry of the tapped hole via the OnShape geometry. (You might own a CNC that can do tapping, but that wouldn't depend on the geometry of the part produced by OnShape. Instead, it would use your CAM program's tool changing instructions.)
  • rick_randallrick_randall Member Posts: 417 ✭✭✭
    edited July 2024
    I'm a little confused, Are you -
    1), going to make the nut yourself ?
    2), just need a 3D model to use in an assembly ?
    If it's 1), then use hole tool, so you can make a drawing with the thread callout (like james said).
    If it's 2),  in your assembly, use "insert" command / "standard content" to insert a ready made M4 hex nut (but won't have 3D threads)
    Note: 3D threads are a resource hog, and makes a mess of drawings - On-shape recommends that you avoid them, unless you have a specific reason, or need.
    If it's not one of the above, explain more, we will try to help. Good luck
  • rlbrkrlbrk Member Posts: 31
    I want to crate and print a nut for the black screw in the picture, my qustion is how can I get it to be functional and match the screw size so you can screw the 2 parts together
  • martin_kopplowmartin_kopplow Member Posts: 1,317 PRO
    Print a nut with just a plain core hole and use a tab cutter when printed. That'll be more precise, given we are talking a tiny M4 bolt.
  • wayne_sauderwayne_sauder Member, csevp Posts: 651 PRO
    @harel_barak952
     Have you looked at this tool and played with the offset settings?
    https://cad.onshape.com/documents/5c0528b62c1fbb13a2a0e739/v/f86229e7f586f8517a2068a9/e/4e0b9c68b36eb2784e7e1aa8
     If you are printing it, trial and error may or may not work, depending on the printer's precision.
     The suggestions above are usually preferred, but if it's a one-off, you can always try.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,094 PRO
    Don’t print an M4 nut. Go to a hardware store and buy one.
    Also any video suggesting to subtract the male thread from a solid to form a female thread doesn’t know what they are talking about. That’s not how threads are made.
    If you must print threads, use one of the thread generating FS in Onshape. You can play around with the clearances in the FS to get a nice printed fit.
