Cannot split curved part with curved surface
martin_danger
Member Posts: 30 ✭
Hi,
https://cad.onshape.com/documents/30aa714d9ba1405b6c4962b3/w/abd3881b0b7f5b4bdc438106/e/422cc167d73e7cdd700f89e3
I'm getting an error when trying to split my circular part.
I've extruded a surface from a line that I sketched using the spline tool.
At first, I thought the error was from the surface starting/ending at exactly that same place as the part but extending the surface past the part boundary didn't help.
The error is unhelpful - it says I should check the input.
Can anyone spot what Onshape is unhappy about with my inputs?
p.s. how do I resize images that I insert into the post? These are huge...
https://cad.onshape.com/documents/3cf276f8301baff7a0db7759/w/1e158608d1e9ff9271528a0b/e/b2531bfb2e5e72f82fd36e6c
https://cad.onshape.com/documents/80bf22684ee4190d6b5e8707/w/97687269d77daaf87ac5c29e/e/25e3164a0d723fa2ba82eafa?renderMode=0&tangentEdgeStyle=1&uiState=669540989a078755030dc31c
Resizing images is still a mystery to me too. but it is possible...on this thread the gifs were huge, now they are as intended.
https://forum.onshape.com/discussion/24026/forum-images-messed-up
1. You cannot create non-manifold geometry in Onshape - the geometry engine will disallow it. Therefore you cannot split the wheel with a single surface (as this zero thickness cut would attempt to create non-manifold geometry)
2. The axis of the circular pattern you used is not the axis of the wheel...
Knowing this, have a look at my document. I created a Mate connector to be the axis of the circular pattern. I Boolean merged two of the three surfaces and used them to split the part. I then split the part one final time with the remaining surface.
(The three surfaces could not be boolean merged into one as that would, yes... create non-manifold geometry.
The initial surfaces (I assigned appearances for clarity):
After the boolean merge:
After the two split features (I did not "keep tools"):
https://cad.onshape.com/documents/7ceab33ba94460b718f1a013/w/13174314ff0975a7688fb585/e/17c2c37e71b6be252d9483d3
[Edited to add: the last Part studio in my doc ^^^ has a crazy but effective way to achieve it using only one split feature...
Split:
The options here are very helpful - it's great to have a forum like this to help with ideas when I run out of new ideas myself.
