Modify an existant view
JP2024JP2024 Member Posts: 7
HI,
I would like to modify an existant view. For example, modify the shift 7 view (change rotation, camera fullscreen, etc..) and save it. Not in the panel Named view.
Thanks.
  • S1monS1mon Member Posts: 4,074 PRO
    It's not possible (at least at the moment) to change the default views. Other than modeling things in a different orientation, or adding a transform after modeling, there's not much you can do about that, other than the named views.
  • JP2024JP2024 Member Posts: 7
    OK !
    Thanks S1mon.
