How to draw a bugle
paul_schröflpaul_schröfl Member Posts: 4
I want to draw objects which have a lot in common with the bugle I've attached:
If it was straight instead of wound, it would be easy:  Create a spline, and rotate the spline around an axis. This would result in a large,,straight  tube (which could be used to make music, too)
But then this tube should be  bended along a given 3D-spline.
How could I do this? Is there a way to bend some  part along a curve?
Or is there some better way to draw a bent tube?
  • paul_schröflpaul_schröfl Member Posts: 4
    @glen_dewsbury :   Of course, I could simplify my model and break it down into simple parts like cylinders, tori, and revolution bodies. However, that would lead to a huge number of tiny parts. Imagine I have a stretched trombone, which has no parallel walls at any point and also no circular cross-section (therefore I can't use cylinders or a torus). I then bend this tube along a three-dimensional spline. The only solution that comes to mind is to construct a plane normal to the spline every 5mm, draw the cross-section on the plane, and connect the individual cross-sections. But that is extremely tedious.
  • S1monS1mon Member Posts: 3,876 PRO
    You will need to be more specific with the shape you're trying to create. Typically you want to start with the smallest number of cross sections possible with a loft or other surfacing, and only add when necessary to get the shape you want. There are some custom features to create freeform 3D splines, but a lot can be done with 2D pieced together and/or intersections and/or bridge curves. It really depends on exactly what shape you need.
