Combining Parts Created by Boolean Operation in FeatureScript
Srujan_Pandya
Member Posts: 2 ✭
I have written a featurescript to sketch an extrude a bounding box and then I had performed a subtraction boolean operation between the main model and the bounding box. Now, I want to access those bodies that would be created by this boolean operation, and then combine (unite) those parts created from this boolean operation (apart from the bounding box). I was thinking of accessing those parts using qCreatedby(id + "boolean1") couldn't get anything to work.
Posting your error messages would help, as without the rest of the code its hard to tell what other mistakes you've made.
Does des_height have units?
OperationType is not a valid input for opExtrude
Does the extrude work? is it just the boolean that doesn't work?
Does your sketch1 exist?www.smartbenchsoftware.com --- Renaissance --- Kestrel -- SmartLink
Experts in Onshape Automation - Custom Features and Integrated Applications0
