Replication now giving different options.
Brandon_Lim
Member Posts: 4 EDU
I was using The drop-down menu to replicate in assemblies is now gives different options than what I used to have. I normally do mates via edges and I would do "Match individual edges" which worked brilliantly. But as shown in the screenshot, previous projects that did use that option still have that option and work, yet my new one does not. Is this an onshape issue or a setup issue? I have tried adapting to the new options to see if they work similarly but have not been able to get any successful replicates.
For context: I want to be able to put the dark blue pieces on the other diagonally oriented faces of the light blue part.
Your shape doesn't really have an edge, that's why its not in the drop down.
Circular pattern would probably be the best choice for what you have.
