Adding a axis via mate option for assembly circular pattern.
Brandon_Lim
Member Posts: 4 EDU
Similarly to how you are capable of doing a circular pattern with the axis via a mate connector on a part, I think it would be a good quality of life to be able to be able to do the same in assemblies. Currently the only other way to do this without adding more geometry to reference as a axis (like a hole or any kind of round interior or exterior feature) would be to do a replicate feature which is less convenient as you have to manually select the face/edges which can be tedious for larger tasks. See examples below for the 1. Example of this feature already being integrated, and 2. An example where this feature might be useful in an assembly.
