AS/NZS Structural Steel Onshape Material Library
Oliver_Couch
Member Posts: 230 PRO
in General
Hi all,
I spent a bit of time yesterday entering the material properties for structural steel from AS/NZS 1163, 3679.1, and 3678 (3679.2 - welded beams are made from plate conforming to 3678).
I made it public so you should be able to find it by searching, but here's a link to the onshape document: https://cad.onshape.com/documents/a2ad4b32d709b5c86a4cb123/w/8fbece5d7ecb0bcefec18e1d/e/5ce5a3fbce7efc16452d6e4d
Strength properties vary with cross section, so there's a pretty large number of grades in there for use in FEA. I've also included basic named Grades for when you just need to annotate the material.
Here are the relevant tables from the standards:
AS/NZS 1163 - Cold-formed structural steel hollow sections
AS 3679.1 Structural Steel - Part 1: Hot-rolled bars and sections
And finally, AS/NZS 3678 - Structural Steel - Hot-rolled Plates, Floorplates, and, Slabs
Oh, and I pulled the density, poisson's ratio, and elastic modulus from Australian manufacturer data (it's just standard data for steel).
2
Hi @Oliver_Couch I'm very new to analysis in OnShape and this is the first post I've ever read. So just wanted to say thanks for your efforts here - amazing and so useful. I'm really appreciative.
Cheers,
Carl.
