Helix End Point from Mate
Jonathan_HutchinsonJonathan_Hutchinson Member Posts: 145 PRO
Could there be an option for helix end points to be selected from mate connectors?
  • CFriedCFried Member Posts: 22 EDU
    edited July 2024
    Mate connectors are pretty much aligned planes, not points.
    Trimming with a mate connectors will also trim along the whole "mate" plane.
    Edit: forgot the obv "fix". Put a sketch with a point on it. But probably not what you wanted
  • Jonathan_HutchinsonJonathan_Hutchinson Member Posts: 145 PRO
    Well, the alignment of the mates XY plane would be used as termination, I suppose. I'm not sure how a single point (linked to a plane of a sketch it was drawn on) is any different.
    Yeah there are ways to resolve this, but the feature is looking for a point and a plane is not a point.
    There should be a easy way to select the origin of the mate connector for a proper solution imo.
