how to turn off the lasso and use the rectangle?
tom_lahey
Member Posts: 18 ✭✭
sometimes a get the rectangle, then it will switch to lasso, how to control it while deleting
I will try tonight, Thanks...right now it seems like all I can get is that mouse trace. it seems very elusive to get the rectangle every time. Maybe I need to slow down and let the server update me0
AFAIK there is no lasso select in OS. The selection rectangle works in a touch or surround mode depending on you drawing it from left to right or right to left, though.
here is the lasso and the rectangle from the snip command , I have not yet figured out how to turn off the lasso, it seems to have a mind of its own0
@tom_lahey
That's not a lasso. It doesn't select things. That's a trace of where your mouse has been. It will trim bits of sketches which it crosses.Simon Gatrall | Product Development, Engineering, Design, Onshape | Ex- IDEO, PCH, Unagi, Carbon | LinkedIn
interesting, but useless to me,, how to I get it to reliably give me the rectangle?0
I doubt it, I am pretty mouse centric, I only use the escape key...still a newbie0
